Ecu Codes
richie
Occasional Poster
  Posted:Jan 25 2003, 10:29 AM
Here are the ECU error codes.To access the codes turn ther ignition to on , dont start the car.Single digit codes are a eries of short flashes and two digit codes use a long flash followd by the right amount of short flashes . these are teh codes for 85-89 PGM-FI
code 0 - ECU
code 1 Oxygen content A
code 2 Oxygen content B
code 3 MAP sensor
code 4 Crank angle sensor
code 5 MAP sensor
code 6 Coolant temp
code 7 TPS sensor
code 8 TDC position sensor
code 9 N0.1 cylinder postion sensor
code 10Intake air temp sensor
code 11
code 12 Exhaust gas recirculation system
code 13 atmoshperic pressure sensor
code 14 electronic idle control
code 15Ingition output signal
code 16 fuel injector
code 17 Vechicle speed sensor
Teamevade
2 replies since Jan 25 2003, 10:29 AM
