| Texy_5
| Posts: 50 |
| Member No.: 2675 |
| Posted:Feb 6 2005, 02:23 PM |
any one know the price of the heavy duty clutch for the 2.2, 5 speed (AT2) 87up. the normal one cannot take my style of driving also does any body else have the part number for the rocker cover gasket
thanks in advance |
| SABBAi
| Regular Poster |
| Posts: 131 |
| Member No.: 918 |
| Posted:Feb 7 2005, 09:59 AM |
For my rocker cover gasket, I went to Repco and told them what I was after. Didn't cost too much.
| TOKEN
| Posts: 52 |
| Member No.: 2277 |
| Posted:Feb 8 2005, 01:27 PM |
| i got my clutch from ACL parts cost bout $350-$400 cant really remember. but it grips like a MOFO. |
| Texy_5
| Posts: 50 |
| Member No.: 2675 |
| Posted:Feb 9 2005, 04:53 PM |
| thanks guys, is there any oil leak hotspots i should know of?. It disappears faster than normal. |
| Posted:Feb 9 2005, 08:51 PM |
not really, its probably seeping mostly through your gasket, also make sure the metal pipes to the turbo are intact, run your fingers along them when the engine is cool since they have been know to crack....
the cars can burn a bit if you push them, maybe try using a thicker oil, if your using full synthetic and your cars got more than say 120k then i'd definately switch to a semi like mobil S.
I got my HD daikin clutch for $350 at a local retailer, has a bit more grip and only is a little heavier than stock so you wont have viens popping out of your forehead between gear changes |
| Texy_5
| Posts: 50 |
| Member No.: 2675 |
| Posted:Feb 14 2005, 06:51 PM |
Turbo? what turbo (the turbo is what my car would greatly appreciate) i dont have to worry about that cos im NA. Thanks for that. Does the heavy duty clutch make any differance cos i got a quote for that at $330 not fitted |
