| zorb_rules
| Posts: 322 |
| Member No.: 1812 |
| Posted:Sep 15 2004, 08:00 PM |
OKay first of all ya know all the warning lights on the dash.... What does the one that says REAR mean it comes on everytime I brake but my brake lights arent out???
Secondly: The lights in the door how can I replace the bulbs ones blown and I figure since ones out Ill replace em all with red or blue bulbs.
Thanks Heaps Guys |
| SABBAi
| Regular Poster |
| Posts: 131 |
| Member No.: 918 |
| Posted:Sep 15 2004, 10:28 PM |
Check your fuse under the dash. But it's funny that your brakes are still working. have you checked both globes? Your car has a hi mount stop light. Check the globe IN the tail gate. If you open the tail gate, look up. There will be a cover. Pop this out, and you have a plastic sleeve under there. Take the globe out, and replace it. Or, check that there isn't some dicky wiring around the rear globes. Or, it could be that when you have your headlights on, one of your tail lights could be blown. The tail light, and stop light are in the same bulb.
As for the globe in the door trims, you need to take the inner trim off. Take your arm rest off, you need a flat head screw driver to pop the cover out above the screw. Next get to the Phillips head screw with a big driver. Next take the lower screw out. Take off the door handle surround. You need to gently pull the bottom away from the door. It has little pop in clips. Then slide the panel up, and manouver the handle out. Make sure that you don't rip the wiring out that goes to the bulb, it connects between the inner door and the panel. Undo the clip then lift out the inner panel. Replace globe, and fit it again. Should take about 1/4 to 1/2 to complete. |
| zorb_rules
| Posts: 322 |
| Member No.: 1812 |
| Posted:Sep 16 2004, 05:36 AM |
Thanks man like I always say u rock. yeah but no brake light issues at all there all working so it must be wiring Ive had a quick look at it doesnt look like theres any probs. The other thing is the light doesnt always go on only sometimes...????? Got me stuffed BUt yeah....
P.S I wanted to check somethin with my tailgate light anyways but I cant get through they plastic (MY drug pocket if you remember) |
| zorb_rules
| Posts: 322 |
| Member No.: 1812 |
| Posted:Sep 16 2004, 02:19 PM |
well i finally got into that globe in the tailgate turns out that it was like half blown so there was a connection sometimes but not all the time. So ive replaced it and im all good now. |
| zorb_rules
| Posts: 322 |
| Member No.: 1812 |
| Posted:Sep 17 2004, 07:18 AM |
| HEy while Ive got this bit open What the hell is the like metal box thing under the front passanger seat and why isnt mine connected?? (as in theres wires comin off it that dont lead anywhere). |
| Posted:Sep 20 2004, 02:17 PM |
hey my car is a shitbox
This post has been edited by mx68u on Sep 20 2004, 05:59 PM |
| zorb_rules
| Posts: 322 |
| Member No.: 1812 |
| Posted:Sep 20 2004, 04:12 PM |
ohh watch out everyone here comes the big man braggin bout his lil vn on the internet man ya cant brag on here it just means ya all talk take it to the streets and then find out ya smart ass.
P.s what engine are you up to number 5??? Ohh and also what the hell are ya bragging about ya car in a post named tx5 owners for??? are u bloody stupid?? |
