| Vanmx6racer
| Posts: 308 |
| Member No.: 31 |
| Posted:Oct 29 2002, 10:05 AM |
Picture "How To" Guide for Headlight Sanding
-------------------- www.mx6.com www.mazdatalk.com ~VanCity Invader Style~ I4 powered and im still running with the big dogs! |
| Vanmx6racer
| Posts: 308 |
| Member No.: 31 |
| Posted:Jul 10 2003, 06:02 AM |
1. Look at your nasty, cloudy headlights... blech
| Vanmx6racer
| Posts: 308 |
| Member No.: 31 |
| Posted:Jul 10 2003, 06:03 AM |
2. Lift hood and remove your funky headlights
| Vanmx6racer
| Posts: 308 |
| Member No.: 31 |
| Posted:Jul 10 2003, 06:04 AM |
3. Remove the clips and the front clear cover to the lights.
4. Drop the covers into a bucket of water and OxiClean to remove fog from inside and clean the plastic.
5. Sand the headlights down to a powdery white with a medium medium grit (800-1000 grain) sandpaper, then again with a HIGH grit (1200-1500 grain) sandpaper. Sand everywhere you see the nasty oxidation.
| Vanmx6racer
| Posts: 308 |
| Member No.: 31 |
| Posted:Jul 10 2003, 06:06 AM |
6. Drop the covers in another bucket of water and OxiClean to further remove grime that was trapped and is now released. 7. Dry the covers off and apply coats of clear spray paint evenly over the cover.
Note: you can apply as many clearcoats as you desire, but be sure to make them LIGHT and EVEN coats of paint!
| Vanmx6racer
| Posts: 308 |
| Member No.: 31 |
| Posted:Jul 10 2003, 06:07 AM |
8. Pop the covers in place, snap on the clips, and return them to their home!
