| eski boy
| Posts: 9 |
| Member No.: 378 |
| Posted:Aug 27 2003, 12:10 PM |
I have an escort running a Mazda FE 2litre Turbo and i was going to use the standard computer, but it's becoming a major head ache. I want to go aftermarket but i just don't know which one to go for. I was thinking Microtech MT-8 or i can get a EMS for about the same price. Any suggestions ?
-------------------- Might not be big, but geez it's good lookin' |
| punhatch
| Posts: 3 |
| Member No.: 785 |
| Posted:Jan 4 2004, 09:36 PM |
Will you consider WOLF 3D? I saw their ad in the magazine.
Don't know they are good or not.
-------------------- Turbo Kit on the way............................ |
| Posted:Jan 24 2004, 08:29 PM |
go the mirceotech over the EMS, if you installing it yourself, but that is if they know the motor. As when you order a microtech tell the model engine number and they send you the lot for that motor triggers sensor or for it to read factory snesors. We had mircoetech on a turboed 20 Valve corolla gave use 3bar map sensor a trigger point for the variable intake timing, worked fine just had alot of trouble tunning it, we installed it got it runing with crude maps, but just hard to tune due to Varibale timing. got it almost right on, then jsut bought TRD cams and by by variable and hello 13.2 eastern creek onstreet tyres 16 psi and S4 RX-7 cooler was great, too bad it was to only last unitl a tree decided it's faith was that the owner ?
